where do I post?
hogarth27
I don't see from the titles of the various fora here where I could ask the collective wisdom of this site what could be the problem with my MZ-NHF800, which was working fine on July 3d, as I did use it to kill time in the waiting room.
Yesterday, July 4th, I intended to make another HIMD disc of music, but it would not come on.
Yes, I checked the manual and let it sit and dry, in case it was moisture. The only thing I can think of that might be involved is that I used the outside power instead of battery, as is suggested.
Well, I seem to have posted it here.
I'll check in often, so if anyone tells me a better place to check, I will be thankful.
