Sony_Fan Posted July 28, 2007 Report Share Posted July 28, 2007 Let's say I transfer mp3s (no conversion) to my RH10. Then I take that disc and play it back on an RH1/M200. Will the playback sound be hindered because an RH10 was used to transfer the music, or will the RH1/M200 still play the mp3s clearly? Quote Link to comment Share on other sites More sharing options...
RoGeR Posted July 28, 2007 Report Share Posted July 28, 2007 From my experience, the MP3 transferred to RH10 sounds better on the RH1. BUT... what I also did find was, if I'd transferred the MP3 to the RH1 first, then it actually did sound better on the RH10 too. I never did any test or interrogate the files and this was purely based on my listening. Maybe you could try and investigate further. Quote Link to comment Share on other sites More sharing options...
Sony_Fan Posted July 28, 2007 Author Report Share Posted July 28, 2007 From my experience, the MP3 transferred to RH10 sounds better on the RH1. BUT... what I also did find was, if I'd transferred the MP3 to the RH1 first, then it actually did sound better on the RH10 too. I never did any test or interrogate the files and this was purely based on my listening. Maybe you could try and investigate further.Interesting. I'll have to wait til next week when I get my RH1/M200. Quote Link to comment Share on other sites More sharing options...
Avrin Posted July 28, 2007 Report Share Posted July 28, 2007 Any MP3s transferred to a Hi-MD disc by anything able to do this will play:1. Hindered: by 2nd generation units (RH710, RH910, M10, RH10, M100).2. As they should: by 3rd generation units (RH1, M200).Problem closed.Just a little addition. The 3rd generation units (RH1 and M200) are able to transfer AND play 48 kHz MP3s. And that with excellent quality! Absolutely perfect for DVD rips! Quote Link to comment Share on other sites More sharing options...
Sony_Fan Posted July 28, 2007 Author Report Share Posted July 28, 2007 Any MP3s transferred to a Hi-MD disc by anything able to do this will play:1. Hindered: by 2nd generation units (RH710, RH910, M10, RH10, M100).2. As they should: by 3rd generation units (RH1, M200).Problem closed.Just a little addition. The 3rd generation units (RH1 and M200) are able to transfer AND play 48 kHz MP3s. And that with excellent quality! Absolutely perfect for DVD rips!Are you referring to DVD audio albums? Quote Link to comment Share on other sites More sharing options...
alexis Posted July 29, 2007 Report Share Posted July 29, 2007 Any MP3s transferred to a Hi-MD disc by anything able to do this will play:1. Hindered: by 2nd generation units (RH710, RH910, M10, RH10, M100).2. As they should: by 3rd generation units (RH1, M200).Any hints about the DH10P performance? Quote Link to comment Share on other sites More sharing options...
Avrin Posted July 29, 2007 Report Share Posted July 29, 2007 Chris G, I am mainly referring to music DVD-Video rips. There are lots of music DVD-Videos with 48 kHz LPCM stereo soundtracks, and these are good for ripping to 48 kHz MP3s. But some DVD-Audio discs also contain rippable 48 kHz (and above) tracks, which may be used for the same purpose. Unfortunately, most DVD-Audio discs are copy-protected in a serious way, thus preventing direct rips. There are ways to circumvent most copy protection methods though.storm shadow, yes I forgot the DH10P. It is a second generation unit, and thus hindered. Quote Link to comment Share on other sites More sharing options...
raintheory Posted July 29, 2007 Report Share Posted July 29, 2007 I can confirm that the DH10P is a hindered Mp3 player. The RH1 sounds much, much better. Quote Link to comment Share on other sites More sharing options...
