internal mini disc player
internal
  internal said:
Can one buy internal minidisc players and if not, did they ever exist?
yes they existed , for the medical community , and were Drive bay installed , just like a DVD or CDRW . And were used in Electron microscope storage , and other for photo and audio..
a list .............
http://minidisc.org/md_data_table.html
Edited by Guitarfxr
  internal said:
thanks.
in that case, how do i transfer files to PC?
http://forums.minidisc.org/index.php?showtopic=7070
I don;t think it was possible with internal MiniDisc drives. I think they were mostly designed for MD-DATA discs, except the VAIO drives that were probably NetMD, which is 1-way anyway PC>MD
Edited by raintheory
oh!
and thanks...
  sector001 said:
there was a couple of Sony VAIO PC's that came with a NetMD drive in it. had i waited a little while longer, i would've bought one of those PC's with the MD drive in it. instead i opted for the dvd recorder.
http://esupport.sony.com/US/perl/model-hom...amp;region_id=1
Perhaps i'll look out for one of those...
thanks
Edited by internal
  Guitarfxr said:
You need an RH1 or M200 to transfer to PC , those are portables , but they are USB , and Work with Macintosh as well , actually probably easier with Mac , the Sofware footprint is small , with no extra bells an whistles to get in the way . All HiMD formated files come in as WAV to the Mac
thanks for that.
i'll need £200 then to sort this all out.
bye
