Farmpunk Posted September 26, 2007 Report Share Posted September 26, 2007 (edited) Hello. Stumbled on the forum while battling an annoying problem.I have an MZ-M100. The recording works fine. I can transfer the files to my laptop. What I can't do is get the files into a specific audio editor. I'm a broadcast journalism student and Must use a program called NewsRoom 4. I've been told the files must be 32 000 bits, and mono files. The Newsroom4 audio editor will not accept the sound files as I have them configured. The sonicstage files will not transfer to the audio editor without a "Err, Invalid WAV Format." I can play the files with windows media player, audacity, but this audio editor won't accept the file.I'm fucking terrible with software, by the way.Any clues?fp Edited September 26, 2007 by Farmpunk Quote Link to comment Share on other sites More sharing options...
Strungup Posted September 27, 2007 Report Share Posted September 27, 2007 Hello. Stumbled on the forum while battling an annoying problem.I have an MZ-M100. The recording works fine. I can transfer the files to my laptop. What I can't do is get the files into a specific audio editor. I'm a broadcast journalism student and Must use a program called NewsRoom 4. I've been told the files must be 32 000 bits, and mono files. The Newsroom4 audio editor will not accept the sound files as I have them configured. The sonicstage files will not transfer to the audio editor without a "Err, Invalid WAV Format." I can play the files with windows media player, audacity, but this audio editor won't accept the file.I'm fucking terrible with software, by the way.Any clues?fpYou mentioned that it DID play in Audacity , there is where you should start . In Audacity you can Resample the file or "Save As" and select bit rate . and Mono or Stereo settings , spend some time learning Audacity . Go thru the help files and tutorials , also online at Audacity's site tips and trix . After resample you can then place the file in Newsroom . and it should work fine. Quote Link to comment Share on other sites More sharing options...
Farmpunk Posted September 27, 2007 Author Report Share Posted September 27, 2007 Thanks, frustration was clouding my mind yesterday. I'm sure I'm missing something simple. Quote Link to comment Share on other sites More sharing options...
A440 Posted September 30, 2007 Report Share Posted September 30, 2007 In Audacity, look under Edit at Preferences. It gives you lots of ways to save files, including Mono. Quote Link to comment Share on other sites More sharing options...
