Simple Burner Communication Errors on Version 2.0
grf
Hi,
Just a quick note to say that I have diagnosed that Simpleburner 2.0 can have the communications to the MD player broken by the Kaspersky software scanning the startup objects which may include scanning USB attached disks.
The result is that the recording session aborts and the PC needs to be restarted to reset the USB communications.
This was with and ASUS Pundit PC running Windows XP and Kaspersky 6.0.
The fix is to suspend Kaspersky until recording is complete. This fault may happen with other anti-virus SW.
Best regards
Graham
