chris_caudy Posted November 6, 2007 Report Share Posted November 6, 2007 I've just tried to backup my library as a matter of course and the above error pops up. The destination had 186GB free, the Backup tool reported ~52GB required. This happened twice until I specified a different destination (USB enclosure hard drive). Any ideas, like what does error 0x2002 actually mean? Quote Link to comment Share on other sites More sharing options...
A440 Posted November 7, 2007 Report Share Posted November 7, 2007 chris_caudy said: I've just tried to backup my library as a matter of course and the above error pops up. The destination had 186GB free, the Backup tool reported ~52GB required. This happened twice until I specified a different destination (USB enclosure hard drive). Any ideas, like what does error 0x2002 actually mean?Was the destination on a USB hub? A RAID array? Something that made SonicStage confused about where it was or whether it had enough power? Quote Link to comment Share on other sites More sharing options...
chris_caudy Posted November 7, 2007 Author Report Share Posted November 7, 2007 A440 said: Was the destination on a USB hub? A RAID array? Something that made SonicStage confused about where it was or whether it had enough power?The original destination was an internally mounted SATA hard drive, this was the destination that threw up the error. Redirecting the backup to an externally USB hub connected hard disc was successful. Odd ... Quote Link to comment Share on other sites More sharing options...
Sparky191 Posted November 9, 2007 Report Share Posted November 9, 2007 I don't see why you'd use the backup tool. myself. You can do it manually more reliably. http://forums.minidisc.org/index.php?showt...8&hl=backup Quote Link to comment Share on other sites More sharing options...
raintheory Posted November 9, 2007 Report Share Posted November 9, 2007 Personally I follow this method to remove DRM from my files: http://forums.minidisc.org/index.php?showtopic=16088Having done that, the files can be stored/moved anywhere and then re-imported into SonicStage with no problems. Quote Link to comment Share on other sites More sharing options...
