car minidisc problem
Hi, i needs some help i just imported a nissan 350gt ( g35 ) from Japan to Australia.
The car comes with a mini disc player. Which worked fine until i put the disc
in the wrong way. now when i insert a disc i get a ( check disc ) error message. Have i stuffed the player? Any suggestions on a fix?
Regards Glenn
Regards Glenn
Hi Glenn,
Try taking power from the MD unit and see what happens. Also see if you can see in the door that the disc slides in and see if something got jammed or bent. What unit is it?
Bob
