MD LP question new decks
kevs
Question, I have for long time the MDS-JB940.
I can record LP, but default is normal mode 80min.
the new decks for sale, MDSJE480, are advertised as Long Play modes. Curious do you have to record at MDLP with these only?
And curious, besides not having a digital out, is pretty much same as what i'm used to? ie remote control and rest. thanks!
No you do not have to record in LP mode , in the menues you choose the record mode , SP , Lp2 , LP4
If your using a portable player that doesnt do LP , then select the SP mode for recording , that way it will play in the portable as well as the deck .
Dont know about the remotes for the decks , I would assume ( which is a dumb thing to do ) that the remotes are system specific, in other words each deck will have functions that will only be available thru he proper remote . On Portables , the same issue applies , The 40elk is probably the coolest remote for MD , but it doesnt work with older MD units and on the units it does work with there are different functions .
Whereas the Remote for the Unit in question , will access certain functions that will NOT be available on others.
