Strungup Posted January 15, 2008 Report Share Posted January 15, 2008 I just removed iTunes from my Macbook pro . Reason: After doing a transfer from iTunes folder , MP3 conversion of some podcasts ( French for Beginners) and the transfering said MP3's to my HiMD while iTunes was open , all of the sudden iTunes looked a lot like the blue screen of death , all Garbled and mangled in appearance , so I quit (force Quit) then restarted iTunes , all looked normal and played normal . so I listened to jams for awhile , then i went to quit iTunes , it would quit , log out then pop right back up , it did this 30 times with a span of about 2 minutes in between quitting and it popping back up . I tried repairing permissions , still did it . I used AppDelete for Mac to can it , then moved that folder out of the trash to the desktop opened the folder and began getting rid of resource files first, then individual proccess file after that , down to the final package Itunes executable hidden in the MacOS file. I have COG for Mac as a music player , and it plays everything that iTunes will not , Shorten Flac, monkey audio, etc . I use Switch to convert stuff to MP3 , and it will convert the Podcasts to mp3 as well ( download on demand will download a file called "aauca" or similarand then it can convert the m4a files to wav or whatever you want.iTunes was the only reason I would want an iPood , but now that I have seen it as a security risk , I will not use it . for Cog , just drag files to it and hit play . Quote Link to comment Share on other sites More sharing options...
Strungup Posted February 13, 2008 Author Report Share Posted February 13, 2008 Update ,........ they fixed the iTunes problem sent out an update notice , and a Securty update as well , go figure . Quote Link to comment Share on other sites More sharing options...
