goof_chewy Posted January 21, 2008 Report Share Posted January 21, 2008 I have the MZ-R50 and the MZ-R700, but am currently stuck without power adapters for each. My plan is to solder some correctly-fitting adaptor plugs on two non-Sony universal adaptors, and use those as my units' power supplies. Question: What amperage is required for these power adaptors? The user manuals for each say nothing about current, only voltage (6v and 3v, respectively.)goof_chewy(not my real name) Quote Link to comment Share on other sites More sharing options...
Strungup Posted January 21, 2008 Report Share Posted January 21, 2008 I have the MZ-R50 and the MZ-R700, but am currently stuck without power adapters for each. My plan is to solder some correctly-fitting adaptor plugs on two non-Sony universal adaptors, and use those as my units' power supplies. Question: What amperage is required for these power adaptors? The user manuals for each say nothing about current, only voltage (6v and 3v, respectively.)goof_chewy(not my real name) I have the R50 , and Had the 700 , R50 = 6 volts , Tip+ , 800 milliamps (1 amp is ok ) 700= 3 volts , 600 milliamps , Tip+ Quote Link to comment Share on other sites More sharing options...
goof_chewy Posted January 22, 2008 Author Report Share Posted January 22, 2008 I have the R50 , and Had the 700 , R50 = 6 volts , Tip+ , 800 milliamps (1 amp is ok ) 700= 3 volts , 600 milliamps , Tip+Thanks for the info! goof_chewy(not my real name) Quote Link to comment Share on other sites More sharing options...
