dubline Posted January 22, 2008 Report Share Posted January 22, 2008 Hello there,My MZ-RH1 recently gave up the ghost and I need to transfer a disk's worth of recordings for a show that I am playing next week. If anyone in or around the Montreal area would be willing to spare me a few minutes of transfer tiime on their deck I would be much obliged, and am offering two CDs of my work in return (as well as admission to the show, If applicable...)Thanks in advance,David Quote Link to comment Share on other sites More sharing options...
Strungup Posted January 22, 2008 Report Share Posted January 22, 2008 Hello there,My MZ-RH1 recently gave up the ghost and I need to transfer a disk's worth of recordings for a show that I am playing next week. If anyone in or around the Montreal area would be willing to spare me a few minutes of transfer tiime on their deck I would be much obliged, and am offering two CDs of my work in return (as well as admission to the show, If applicable...)Thanks in advance,DavidThat really hurts , If you had more time , I am sure that one of the members here would accept you mailing the disc to them , and convert it to CD , I am in Japan , but would gladly do that for you , and send the disc back to you . The other way you could do this , is find a HiMD player only model , and record to the line in of your computer to Audacity , laborious I know , but it would work . Quote Link to comment Share on other sites More sharing options...
A440 Posted January 22, 2008 Report Share Posted January 22, 2008 I'd love to help you but I live in New York City and will be in and out of town all week. How about contacting Minidisc Canada? They seem to be in Montreal. And they have an RH1 in stock. Maybe they could help you out. http://www.minidisc-canada.comPhone: 514-780-1292Fax: 514-735-5956 Quote Link to comment Share on other sites More sharing options...
Avrin Posted January 22, 2008 Report Share Posted January 22, 2008 What exactly happened to the RH1? Quote Link to comment Share on other sites More sharing options...
dubline Posted January 22, 2008 Author Report Share Posted January 22, 2008 Thanks for the replies,I'm not exactly sure what went wrong with the MZ-RH1, I was doing heavy ammounts of recordings in intensely hot and humid conditions (brazillian amazon) and after two weeks of flawless functioning I got a disk read error, and that was repeated on changing the disk. There seems to be a mechanical misfire somewhere - the unit will go into record mode, but cannot then write nor can it read. If anyone has DIY repair suggestions (I am not very knowledgeable in these matters) let me know. Best,David Quote Link to comment Share on other sites More sharing options...
bobt Posted January 23, 2008 Report Share Posted January 23, 2008 Thanks for the replies,I'm not exactly sure what went wrong with the MZ-RH1, I was doing heavy ammounts of recordings in intensely hot and humid conditions (brazillian amazon) and after two weeks of flawless functioning I got a disk read error, and that was repeated on changing the disk. There seems to be a mechanical misfire somewhere - the unit will go into record mode, but cannot then write nor can it read. If anyone has DIY repair suggestions (I am not very knowledgeable in these matters) let me know. Best,DavidTake the battery out for an hour or so, seems to work with my NH1, try a hair drier on low heat on the unit for a few minutes as well.Good luck, and may the source be with youBob Quote Link to comment Share on other sites More sharing options...
