'CONNECT COMPLIANT SOFTWARE' problem
nosferatu
I have a nw-a1000 mp3 player.Everthing was going fine until I started using CONNECT STORE instead of CONNECT PLAYER.Now when I want to reach artist link,bookmark list or song rating options in my mp3 player I see the message 'connect compliant software'.What's more I can't use connect player to transfer songs I can only use that connect store.Please help!!!
1 answer to this question
I am a bit confused what you mean here.
CONNECT player is the program you use to transfer the songs over to the A series, if you want all the features to be working. If CP runs fine on your PC I recommnd using it, and skip sonicstage all together.
If you can't use CP since it is too slow or loads to long, install sonicstage 3.4, then import the files into it. Next transfer them over to your A1000.
Once that done, open CONNECT player and let the unit sync with the program. I am assuming that you have a library imported into your CONNECT player as well.
Once the program finishes updating the unit, unplug it and all the features should work.
