6079 Posted January 28, 2008 Report Share Posted January 28, 2008 Do you know of anyone or any resource where there are people who have experience doing some post production to live tapings?I have a Modest Mouse show with very overwhelming bass. I could do it myself, but I figure a more experienced person could do much better. Quote Link to comment Share on other sites More sharing options...
Strungup Posted January 28, 2008 Report Share Posted January 28, 2008 Do you know of anyone or any resource where there are people who have experience doing some post production to live tapings?I have a Modest Mouse show with very overwhelming bass. I could do it myself, but I figure a more experienced person could do much better.I am a recording engineer , but I live in Japan , so it would mean shipping for you .I work on a Macintosh , and have mastering software , plus a large collection of outboard gear . Here is an easy way to experiment for you , Download Audacity , for your OS (Windows /Mac /Linux is in the works) then install some third party plugins, there is a 31 band EQ available somewhere , then ( depending on what MD you used) either Import , or Record to Audacity ( to record directly , set the MD audio settings to Line Out , if that is available, then hook the output of the MD to the Line input of your computer) First hit play on the md , and double klk the record meter (top right of the window has a Mic icon (two sets of meters Play/Record) ) the meters should start moving if sound is coming in . Adjust the Rec Gain (slider by the Mic icon) so that the meters are just under 0bd . then rewind the MD , hit Record on Audacity and start the MD .( Audacity has a lot of settings for file quality , inputs , where to store stuff , they are all in Preferences, and for that read the Help file for Audacity and get to know the prog before you do anything.) Audacity is free , http://audacity.sourceforge.net/ Quote Link to comment Share on other sites More sharing options...
A440 Posted January 28, 2008 Report Share Posted January 28, 2008 Guitarfxr is right--if it's just a matter of lowering the bass, you can do it yourself in Audacity, following his instructions. However, and I'm sorry to say this, if you have distortion--if the bass just obliterates or overloads the whole recording, so that you can't hear anything but the distortion--then you aren't going to be able to fix it, and a professional won't be able to do any better. Quote Link to comment Share on other sites More sharing options...
6079 Posted January 28, 2008 Author Report Share Posted January 28, 2008 I am a recording engineer , but I live in Japan , so it would mean shipping for you .I work on a Macintosh , and have mastering software , plus a large collection of outboard gear . Here is an easy way to experiment for you , Download Audacity , for your OS (Windows /Mac /Linux is in the works) then install some third party plugins, there is a 31 band EQ available somewhere , then ( depending on what MD you used) either Import , or Record to Audacity ( to record directly , set the MD audio settings to Line Out , if that is available, then hook the output of the MD to the Line input of your computer) First hit play on the md , and double klk the record meter (top right of the window has a Mic icon (two sets of meters Play/Record) ) the meters should start moving if sound is coming in . Adjust the Rec Gain (slider by the Mic icon) so that the meters are just under 0bd . then rewind the MD , hit Record on Audacity and start the MD .( Audacity has a lot of settings for file quality , inputs , where to store stuff , they are all in Preferences, and for that read the Help file for Audacity and get to know the prog before you do anything.) Audacity is free , http://audacity.sourceforge.net/Thanks for the info.If you actually would like to mix the show, I could set up a torrent for the raw data if that works with your system.Guitarfxr is right--if it's just a matter of lowering the bass, you can do it yourself in Audacity, following his instructions. However, and I'm sorry to say this, if you have distortion--if the bass just obliterates or overloads the whole recording, so that you can't hear anything but the distortion--then you aren't going to be able to fix it, and a professional won't be able to do any better.I think this recording is salvageable. I have done some tweaking in cooleditpro, and there isn't much recorded distortion other than the heavier parts creating a "rattling car stereo" distortion. Mostly it's just very boomy.Sometimes it's hard to tell if bass roll off is needed or not, especially since I'm new to the game. Quote Link to comment Share on other sites More sharing options...
Strungup Posted January 28, 2008 Report Share Posted January 28, 2008 What OS are you on? Quote Link to comment Share on other sites More sharing options...
6079 Posted January 28, 2008 Author Report Share Posted January 28, 2008 What OS are you on?Windows XP Quote Link to comment Share on other sites More sharing options...
Strungup Posted January 28, 2008 Report Share Posted January 28, 2008 It would be better if you Dropped the files in WAV format to a DVD (Data) just as if you were backing up your drive, and mailed it to me . Torrents I dont open my computer to , If you were on a Mac , I could link you to my dot Mac private folder , and you could upload direct to that. Quote Link to comment Share on other sites More sharing options...
