GYM - Cant save files
Hi all
I've just spent hours going through the key generation etc and all seemed to work great. Now that I open GYM (1.2 fails to run due to JIT debugging fault, 1.1 loads sweet and lists all the mp3 tracks as shown on the website) I can't save them to my hard drive. Each time I click save, I get the little window asking me where to save to, but the inside of the window is blank (no windows floder tree). Can anyone please advise as I am desperate to rescue the mp3 files of my NW-HD5.
Cheers in advance
M
Guest Stuge
scooooter,
Welcome to AtracLife!!
You must be doing somehing wrong .I will suggest you to read the GYm Instructuions page carefully again.
Also Do you have DirectX 9.0C(GYM requires this )??
install .net frame work1.1
nice one Stuge
I've just updated to directx 9c and I now get the windows tree when i try to save an mp3 back to my pc.
Unfortunately.............
It still doesn't want to work? It goes throught the routine and creates a folder where I ask it to save to and names it the same as the mp3, but the folder stays empty?
Any ideas welcome. I have tried it on my laptop and desktop, using GYM 1.1 as 1.2 beta fails to load due to a JIT debugging error.
Cheers all :blink:
I have the same problem as scooooter.
" Each time I click save, I get the little window asking me where to save to, but the inside of the window is blank (no windows floder tree). "
I have Dx9.0c installed. My .NET Framework might be 2.0, where can I see this and how can I install an older version?
Edited by Rudolf
Guest Stuge
Go to all programs=>then scroll down to "Administrative tools =>here you will see whether you have Microsoft .NET Framework X.X installed or not ..
Unintall the .net framework using Add/Remove programs ..
