Charging time for mz-m200 and USB 2.0
smundra80
Does anyone know about the charging specifics of the MZM200? It says in the manual that it takes 60 minutes for it to charge to 80% and an additional 2 hrs for 100% charge. After I charge my md player for 60 mins., it seems to shut off. How do I know if it has been charged to 100%?
I just bought my mzm200 a week ago. It doesnt mention anything on the box about USB 2.0 although it does in many reviews. There are a few other things like antiskip G protection 2 and just G protection which seem to be ambiguous. Does my device have Gprotection2 or G protection? Is there much of a difference? Any help would be greatly appreciated.
The RH1 goes into a trickle charge state after the Lights go out , Lithium Ion batteries want a "fast start / slow finish" charge cycle .
so even if the LED is off it is still charging , but at a much slower rate
hope that helps you understand
Yes thank you very much. I actually just kept it charging after the LED went off for the additional prescribed 2 hrs not knowing whether it was charging further. Anyway, now I know it was!
Regarding the Antishock G protection 2 vs G protection. Any difference? Which one do I have on my unit?
Thanks again!
