Transfer recordings from MZ-N710 to MacBook
stupidgirl
hi,
I'm trying to transfer some recordings i did on my Minidisc to my computer (MacBook 2 GHz Intel Core 2). I have been reading lots of different explanations and ways to do it and i'm getting confused. Do I need a software? Do I need a iMic? Can I do it with SonicStage? Does it work with Mz-N710????
In short I'm useless and I really want to find a quick and easy way to do this.... Can anybody help and explain in a simple and clear way?
Many thanks.
x
hi,
Many thanks.
x
Hi Useless,
You need " Hi MD Transfer 2.0 " for the macbook it is much simpler than Chronic Rage , I means sonic stage .And whtever gets transfrred will have to be in HiMD format , not regular MD format
get it here
http://esupport.sony.com/US/perl/swu-downl...&mdl=MZM100
