GrandMasterMark Posted February 25, 2008 Report Share Posted February 25, 2008 Hello all,Awesome forums you have here. I have been reading for a few days now. You guys rock!Here is my situation: 1. I bought a Edirol R-09 a while back to record lectures for my business. I have been using it to record drum workshops and drum circles more than for lectures. I just set it in the middle of the circle while everyone is playing, adjust the input levels accordingly (using internal mics), and let it go.2. I have been using Sound Forge 8.0d to clean up the tracks and burn to CD's.3. Bought a set of these mics (http://www.audioreality.com/) on eBay with a POS Olympus voice recorder for $51.00. Tested the mics with battery box and R-09 at home with drums and everything seems to work fine.4. I have 3 shows coming up over the next few weeks. Of all the shows, the first one is the one that I really want to record!Now this is where I plead for your help. I have the gear (My Dad has always told me that I have more money than sense!) but I don't have the Guts. With knowledge will come courage and I am hoping to learn from all of you in a very short period of time.What do I do next? What do I need to know about smuggling these technological wonders into a show? What happens if I get caught? This might make a good topic all by itself!Once I am in, where do I hide the Edirol? The battery box?Tips on mic placement for a big show? I have floor tickets and expect it to be LOUD. I am thinking that everyone wearing glasses with Croakies is automatically subjected to a cavity search. Am I right?Any tips on basic settings for the Edirol? A starting point?Is it at all smart to check levels on the R-09 while standing in the crowd? That monitor screen and red "Record" button are pretty bright.Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Strungup Posted February 25, 2008 Report Share Posted February 25, 2008 (edited) if you get caught , your gear could be , and probably would be confiscated . There goes 400 dollars down the drain . This an MD forum , and MD is much easier to conceal ( You did NOT hear that from me ) it just is ........... Not may people here will be up on the R-09 , .............. a few maybe , but the Roland forums might have better info on that portion . The Croakies , and a pair of Glasses cable down the back inside the shirt probably into the pants , R-09 strapped to the inside of a leg 2 cents worth submittedput the glasses on AFTER you get in . Edited February 25, 2008 by Guitarfxr Quote Link to comment Share on other sites More sharing options...
kino170878 Posted February 25, 2008 Report Share Posted February 25, 2008 I always thought that the Edirol R-09 looked a bit like an electric shaver. Just say you wanted to pull a chick on the night and you didn't realise you brought your mate's recorder instead. Seriously though, portability is the key. I think you have more than a good chance of getting through security if you are smart. Research, research, and research into it until you find a solution. Quote Link to comment Share on other sites More sharing options...
