Strungup Posted March 5, 2008 Report Share Posted March 5, 2008 I just downloaded Final , from Apple downloads . No iMic or anyother Griffin Device needed . It Has in the Preferences pane Selection for input, WITH GAIN CONTROL ...+/- 20 db I had my AT 822 connected directly to the line in on the Macbook Pro , increased the Gain 20 db , and hit the record button . YES IT WORKS !!! a litlle noisy cranked AL THE way up. but this means real time transfers from MD , or any other device with a line out will work directly connected to your Computer. That means the Track Marking function in Final Vinyl is now yours for the taking . FREE The layout is simple and clean and looks good . The list of effects are short and to the point .Auto Mark Clear MarksInsert silenceNormalize that is it , plus there is an effect view pane so the when you apply something you can see it in a separate window . Quote Link to comment Share on other sites More sharing options...
Strungup Posted March 5, 2008 Author Report Share Posted March 5, 2008 (edited) testing it right now , Recording , an older MD from the RH1 line out to the Mac input , It doesnt use very much processing power at all when recording . On editing it might be a little more involved , but it seems to be pretty quick .Update :Recording done , playing back the file now , Sound is nice and clean , This was recorded the R50 sometime ago from LP (Vinyl) so I couldnt upload it,Audacity didnt do Track marks per say ( you could cut /paste/ copy ) but this has track markers and Very nice VU meters.Track marked , files separated , and in the process of burning to CD .very easy , I used , Final to mark and separate ( Control klik the track , a window pops up Save as , Name the file tell it where to go) from that folder I use "Burn " for Mac ( very cool prog) import the files in the order I wanted them and Burn an Audio CD .Painless Edited March 5, 2008 by Guitarfxr Quote Link to comment Share on other sites More sharing options...
Strungup Posted March 5, 2008 Author Report Share Posted March 5, 2008 Playback of the CD was spotless , totally Gapless , and it sounded very good . The only thing I noticed was , the Auto Track Mark function didnt seem to work , I will have to play with that .Final Vinyl for mac ,............ Cool Prog. Quote Link to comment Share on other sites More sharing options...
