Lost recording due to power cut
I have MZ-N1. I was recording a very important discussion and accidently the power cord was pulled out by someone's mistake. Since, the discussion was going on, I quickly put the power cable back and pressed recording again. Now the recorder shows only 2 new tracks which are of 5 minutes but it doesn't show old track which was 90 min long. How do I recover that recording?
Please help... Its very important recording.
- KB
Sad to say, but it's gone. After recording, the minidisc needs to save the data--when you hit the Stop button, it's like hitting the Save button on a word-processing document. Your power cut didn't allow that to happen (and apparently your battery was dead?).
Edited by A440
Yep, see the post in my signature re: TOC cloning.
PM me if you need help.
EDIT: Sent you a PM re: TOC Cloning info
Double EDIT: This is the MZ-N1 and not the MZ-NH1 correct? TOC cloning works for the N1 and those older recordings, but not for Hi-MD audio/... you'll need to contact Sony if it's Hi-MD, they might me able to help..
Edited by raintheory
