anawanahuanana Posted April 17, 2008 Report Share Posted April 17, 2008 Hi guys.I have had an MZ-N707 for years now without a problem. However I hadn't used it for about 6 months lately and when I went to record some new discs the other day I'm having problems with the recordings.I am using the OpenMG program that came with the unit, and I've tried updating to the latest version but no luck. What happens is that every song I record onto the disc sounds like it's been recorded to fast and it plays back too quickly and with little hiccups throughout it, if you know what I mean. I recorded a whole disc like this. I've tried messing about with the settings to use LP Stereo, LP2 and LP4 but it doesn't seem to make any difference. I can play discs I recorded last year fine with no hint of speed issues or hiccups, so it's definitely something to do with the way it's been recording recently.Does anybody know if it's a hardware or software issue? Any advice would be gratefully received.Thanks in advance......... Quote Link to comment Share on other sites More sharing options...
anawanahuanana Posted April 17, 2008 Author Report Share Posted April 17, 2008 And just to let you know that after some more research on this fantastic site I just installed SonicStage 4.2 and used it to load a song, both in LP2 and in SP. Same problem both times, so it looks like it isn't a software problem. Now all I need to find out is how it can be recording everything too fast...... Quote Link to comment Share on other sites More sharing options...
raintheory Posted April 17, 2008 Report Share Posted April 17, 2008 Try recording via line-in and see if you experience the same problem. Quote Link to comment Share on other sites More sharing options...
anawanahuanana Posted April 17, 2008 Author Report Share Posted April 17, 2008 Try recording via line-in and see if you experience the same problem.Hi. Thanks for the suggestion. I just recorded a song via the Line In socket and it recorded it and played it back absolutely fine, so the problem seems to revolve around the USB connection. Really am a bit confused now. I was expecting it to be a mechanical problem with the recording head or something. Quote Link to comment Share on other sites More sharing options...
