HELP WITH MACALLY EXTERNAL BATTERY PLEASE
Is it already charged ? there is an ON/Off switch to turn it on , and it should show whether it is charged or not .
Also the best way to charge it is from the 5Volt dc input , the first few times , Lithiums have to be broken in ( Like good headphones )
Guess what! TOSHIBA laptop usb port doest charge it, but a desctop PC I tried does charge it!!!
...it moves in mysterious ways...
That means that that port on the Toshiba doesnt supply enough power . Some laptops are that way .
I had made a topic with the working relationship of ip-a481 with mz-rh10 and rh1. I can say that it doesnt work at all with mz-rh10. No charging, nothing. I will see what will happen with rh1.
make sure to use a standard USB A/B cable ,
I have a Filco 4.4 amp USB pack that works very well with the RH1 , Hours and Hours and HOURS of time , leave it on all day not even think about it .
