madmac47 Posted May 16, 2008 Report Share Posted May 16, 2008 My SoniStage 4.3 has stopped inporting any music files from my conputer. It will inport a CD but not a WAV file from a hard disk. This has worked befor , like a champ. Does anyone have a fix for this problem Quote Link to comment Share on other sites More sharing options...
THIS SUCKS Posted May 16, 2008 Report Share Posted May 16, 2008 if you drag and drop the wav file onto the import screen does it work then? Quote Link to comment Share on other sites More sharing options...
madmac47 Posted May 18, 2008 Author Report Share Posted May 18, 2008 if you drag and drop the wav file onto the import screen does it work then?No drag and drop does not work ether. When I select inport wav files . The pointer alway's switches back to CD , you can select the files to inport but the program stop's responding and lockes up. I can still inport from CD though. Quote Link to comment Share on other sites More sharing options...
raintheory Posted May 18, 2008 Report Share Posted May 18, 2008 (edited) hmm, interesting/you using vista?EDIT: Are the WAV files 16bit/44.1kHz? Edited May 18, 2008 by raintheory Quote Link to comment Share on other sites More sharing options...
madmac47 Posted May 22, 2008 Author Report Share Posted May 22, 2008 hmm, interesting/you using vista?EDIT: Are the WAV files 16bit/44.1kHz?hmm, interesting/you using vista?EDIT: Are the WAV files 16bit/44.1kHz?No i'am using Windows XP Media edition. Is there any other software avable to record on Hi md recorders. I really like the Md format for my music. But this problem is getting me down. Quote Link to comment Share on other sites More sharing options...
raintheory Posted May 23, 2008 Report Share Posted May 23, 2008 A number of users (myself included) have experienced problems transferring tracks on XP while using Sonicstage 4.3Try version 4.2: http://forums.minidisc.org/index.php?showtopic=17769 Be sure to uninstall 4.3 first.The only difference between 4.2 & 4.3 is that 4.3 is Vista compatible. Quote Link to comment Share on other sites More sharing options...
