larujunky Posted June 8, 2008 Report Share Posted June 8, 2008 Hi ^^I would like to ask that Sony ICDUX series with external microphone can record live sound ? And sound quality can compare with Hi-MD ?Thank you for helping Quote Link to comment Share on other sites More sharing options...
Strungup Posted June 8, 2008 Report Share Posted June 8, 2008 (edited) For Portable the only IC or Flash based recorder that will compare in the " Budget realm "is the PCM-D50 .......... I want one myself Edited June 8, 2008 by Guitarfxr Quote Link to comment Share on other sites More sharing options...
A440 Posted June 10, 2008 Report Share Posted June 10, 2008 The specs for it are here:http://www.pczocker.de/sony-icdux-schwarz-...gok4898ego1cu65Frequency response is 40-20000 Hz, not ideal (20-20000) but surprising in a voice recorder. However, we have no idea whether the built-in mics are made to record voice, which would mean they would have a strong bias toward the midrange--no highs or lows. Also, I can't figure out from the recording times what kind of bitrate it is using. It might be good enough for voice and not for music. I wouldn't trust it, but I'd be curious to see someone try to record music with it. Quote Link to comment Share on other sites More sharing options...
ramblie Posted July 5, 2008 Report Share Posted July 5, 2008 So far I know, the ICDUX just made for voice only, not the music purpose... Quote Link to comment Share on other sites More sharing options...
