Strungup Posted June 8, 2008 Report Share Posted June 8, 2008 (edited) Besides HI MD Transfer 2.0 for Mac. There are some very cool ways to get jams . And Also ways to work around problems with MSN Video . If your using Safari ( I have no need for three or four browsers) , When you klik on a link to an MSN video , your greeted with " Your Browser isnt supported " ......pure BS Try this , klik on a MSN video link , where that message pops up in Safari , now.......instead of closing that window or hitting the Back Arrow in the Browser frame , Hit the Delete key . you will be looking at the Video page , from there , klik the MUsic tab , select an artist , and the little + buttonat the bottom right in each of the video frames on the page , adds them to a Playlist ,........................ bam load them , then in the Video window that actualy plays the vids , bottom right is the fullscreen buttonLine out to your MD , Headphones or Line out from the MD to your speakers , there you go . Watching Sheryl Crow , with 15 videos in the Playlist full screen right now . Have fun( The Last Video , is actually the entire concert 82 minutes 11 seconds) Edited July 9, 2008 by Guitarfxr Quote Link to comment Share on other sites More sharing options...
Strungup Posted July 8, 2008 Author Report Share Posted July 8, 2008 (edited) More Mac tips " REC " is a very simple recording program for mac , it has gone thru some changes . It was recently updated to version 2.1 and is a UB for intel This prog lets you select a Region of a recording , and exporting it as AIFF or WAV , also you can select the entire file and export that (Just dont selct anything and it will use the whole file) It also records , has a nice meter , and you can monitor the input , as well as select bit rates . but that is the extent of its capabilities , as I said it is a VERY simple prog , but that is a good thing . Audacity is for effects and more fine detail editing . REC uses very little process power ( hardly any at all ) differences are , the early version of REC ( I have both ) version 1 was an 8 channel recorder , .....simply record 8 channels simultaniously and export as individual wav files , Version 2 is a simple 2 channel recorder with a Loop function , Very useful for creating Apple Loops for Garage Band or , Drum Loops for any other editor , or Import a file and export JUST the guitar solo , as a separate file, Interviews could be broken down into constituant parts , and the renamed as individual tracks . Or a Concert that you recorded on the MD ,........ Highlight a part of the file klik the "Write " button ( the prog is from Europe ) and a window pops up , Name it , tell it were to put it , klik save your done Here is Version 2.1 http://www.apple.com/downloads/macosx/audio/rec.html When you use REC , here is another tip , Go to System Preferences and open "Sound " leave it open , so that Both REC and Sound are open side by side , You now have Level Control and Input selection from the sound window Edited July 11, 2008 by Guitarfxr Quote Link to comment Share on other sites More sharing options...
