feng Posted June 17, 2008 Report Share Posted June 17, 2008 I have a macbook pro 2.2 GHZ with Mac OS X 10.5.2. I am wondering which version of sony stage I have to install. I have installed 2.0 version of sony stage but I only see the MD tracks and I cant do nothing else.thanks for help Quote Link to comment Share on other sites More sharing options...
Strungup Posted June 17, 2008 Report Share Posted June 17, 2008 (edited) feng said: I have a macbook pro 2.2 GHZ with Mac OS X 10.5.2. I am wondering which version of sony stage I have to install. I have installed 2.0 version of sony stage but I only see the MD tracks and I cant do nothing else.thanks for helpYou dont use Sonic stage on Mac ............ MD Transfer 2.0 is the name of the Program for Mac , Sonic Stage doesnt even run on a Mac unless you are dual Boot With Windows http://support.sony-europe.com/dna/downloa...x?l=en&f=MTklike that link to get to the download site. for an English version I think you can select other regions from there as well.Ahhhh you miss stated , ok your are on MD Transfer , To be able to transfer the files to your computer ,there are three things.#1 Your disc needs to be in HI Md mode , not a standard MD ( Which means Older MD's will not transfer , but there is a way around that , I will show later)#2 The tracks you wish to transfer need to have been recorded in Hi MD mode ( Hi LP , HI SP, or PCM) #3 Then , the tracks that appear will show in the Software , in two types , Types that cannot be transfered (Older tracks , Standard MD Mode) will be Grey The Tracks that CAN be transfered will show not greyed out, and you Command klik the tracks you want to bring in , ( Highlight them ) they turn blue , then at the bottom of that window , is the transfer button . Edited June 17, 2008 by Guitarfxr Quote Link to comment Share on other sites More sharing options...
SKDX Posted June 18, 2008 Report Share Posted June 18, 2008 Is the Sony MZ-M200 or any other Sony Hi-MD rec/players compatible with Mac OSX leopard (10.5+)? On all the documentation and user manuals that I have come across I have only read that it is NOT (only with OSX 10.3-10.4). Quote Link to comment Share on other sites More sharing options...
