ILoveMinidisc Posted July 18, 2008 Report Share Posted July 18, 2008 (edited) Everytime i do a Recording now with my Nz-n910 net mdthe Minidisc show Blank discI using the latest sonicstage for Vista and havent had a problem with it on vista beforeSonicstage show all tracks are transfered correctly Songs show up on the right side on the software and on the player while plugged ini can also play the song with player plugged into pc and sonictage and hear the music come out of headphones plugged in playerNow, here comes the problem When i plug out the player And try to play the songs i recorded Player now says "Blank Disc"i also think that i dont can see the Toc edit message at allI then plug in the player again and the PC freezes (this almost never happen is a new laptop)happened once....Sometimes:- The songs recent recorded wont play with the MD plugged into sonicstage either then it make a spinning sound- The songs transfer fine and play fine without blank disc error <---- IM testing this nowALL old MD that i recorded previous this problemare working perfectlyUPDATE:Now i transfered 2 tracksbut the rest of the album wont playthe songs however show up on the right in sonicstage and on the playerjust wont play Edited July 18, 2008 by ILoveMinidisc Quote Link to comment Share on other sites More sharing options...
bobt Posted July 18, 2008 Report Share Posted July 18, 2008 I think your recording head is toast, don't use player any more,, it will start to erae\se discs, sorry,bob Quote Link to comment Share on other sites More sharing options...
kino170878 Posted July 18, 2008 Report Share Posted July 18, 2008 How easy is it to replace a recording head on portables? I guess every portable one day is going to be facing this problem. Quote Link to comment Share on other sites More sharing options...
Superbaldguy Posted July 18, 2008 Report Share Posted July 18, 2008 Sadly, it's not economical to do so.The ribbon connector could also be the culprit as these tend to come undone after a few years of use, you may have better luck trying to solder that together. Quote Link to comment Share on other sites More sharing options...
ILoveMinidisc Posted July 18, 2008 Author Report Share Posted July 18, 2008 (edited) The problem still persist but i can record diskIf i start record an album of 12 Songs after recording i get Blank disc(after MD has been removed and reinserted into the unit)BUt then if I just transfer one song then remove the Md it will play that song fine I then can drag the rest of the songs of the album to the MD that had the one songand it will then transfer fine and workCould this has something to do with the "Start" and "END" recording of a MD? Edited July 18, 2008 by ILoveMinidisc Quote Link to comment Share on other sites More sharing options...
ILoveMinidisc Posted July 18, 2008 Author Report Share Posted July 18, 2008 Can i get a Cleaning -MD and try clean the MD unitmaybe it can extend the lifetime just a bitI dont want to repair it probaly be expensiveI might get a temporary solution by buying some Low-budget new Net-MD older models that they have left over or stock at a sony store Quote Link to comment Share on other sites More sharing options...
raintheory Posted July 18, 2008 Report Share Posted July 18, 2008 (edited) Can you record via line and/or mic-in?If so, then it's a software issue (something with SonicStage and/or drivers), if the same thing happens, it's an issue with hardware (ribbon cable / recording head).Edit if it's hardware, 99% of the time it's the actual ribbon cable, so a cleaning disc won't help (I'm not reven sure if those clean the recording heads anyway).There is a thread around here somewhere detailing how to repair the ribbon cable... I'll see if I can find it. Edited July 18, 2008 by raintheory Quote Link to comment Share on other sites More sharing options...
ILoveMinidisc Posted July 19, 2008 Author Report Share Posted July 19, 2008 raintheory said: Edit if it's hardware, 99% of the time it's the actual ribbon cable, so a cleaning disc won't help (I'm not reven sure if those clean the recording heads anyway).There is a thread around here somewhere detailing how to repair the ribbon cable... I'll see if I can find it.Is the ribbon cable the USB cablebecause i have problem with itsometimes it detect MD when pluggin in sometimes notcould be that cable make the problem when recording? Quote Link to comment Share on other sites More sharing options...
raintheory Posted July 19, 2008 Report Share Posted July 19, 2008 The ribbon cable is a (very) small ribbon-shaped connector inside the unit itself... It connects the record/overwrite magneto head to the main board. It is ribbon shaped to provide flexibility as it needs to be able to move. The USB cable could very well be the culprit, fortunately they are a standard size (Mini- so you should be able to find one just about anywhere that sells USB cables. Quote Link to comment Share on other sites More sharing options...
raintheory Posted July 19, 2008 Report Share Posted July 19, 2008 BTW, here is the thread pertaining to the ribbon cable repair, if that does seem to be the problem:http://forums.minidisc.org/index.php?showtopic=4712 Quote Link to comment Share on other sites More sharing options...
