Strungup Posted July 28, 2008 Report Share Posted July 28, 2008 (edited) I started on the box today ( Finally ) for the supply for my Hardoff obtained Sony ECM-MS 5S Stereo Microphone a websitehttp://www.broadcaststore.com/catalog/By-B...MMS5/ECMMS5.htman imageThis Mic was (and still is ) about 1500 dollars US , I found it damaged in Hardoff , with no connectors or cables for 2,000 yen ( 20 bucks ) It has been sitting in a drawer ever since , but I obtained a cool case for the project recently . Brief descript .... 1: 5 Pin XLR input 2: Two standard 3Pin XLR outs 3: Two 1/8 " unbalanced capacitor coupled outs for Md or any other device 4: two 9 volt Batts for 18 volts Phantom power 5: LED Indicator for battery level 6: Switch for Internal Power , or External 48 volt Phantom Passthru from the XLR connections ( Mixing board ) 7: The ability to have it connected to a mixer , AND the MD at the SAME TIME ( Using both sets of connections ) Those are the objectives , I will post some pix soon of the box , I have to go to Yokohama tomorrow to find the right switch , and Battery holders .( flip up internal types if I can find them ) At the moment all the external connectors are mounted and it looks good , now I have to build the circuit , and the internals , we will see how it goes!!!!Cant wait to hear this thing Edited July 28, 2008 by Guitarfxr Quote Link to comment Share on other sites More sharing options...
Strungup Posted July 28, 2008 Author Report Share Posted July 28, 2008 So this should be even better than your MS959c mic?Doesn't it look a lot like your AT822?I like the manual, detailed spec description and listed accessories. yes this should best my 959a we will see ...... the specs are nice , low noise floor, and really good sensitivity , at 150 ohms , should pickup fly farts pretty well Quote Link to comment Share on other sites More sharing options...
bobt Posted July 28, 2008 Report Share Posted July 28, 2008 yes this should best my 959a we will see ...... the specs are nice , low noise floor, and really good sensitivity , at 150 ohms , should pickup fly farts pretty well sometimes we just have too much informationBob Quote Link to comment Share on other sites More sharing options...
Strungup Posted July 29, 2008 Author Report Share Posted July 29, 2008 sometimes we just have too much informationBobYou just have to Visualize BOB ,........LOL Where is my Pina Colada ???? Quote Link to comment Share on other sites More sharing options...
