FS: Audio Technica ATM10a Microphone
bjsilva
Audio Technica ATM10a condenser microphone for $50. This is a high quality omni directional condenser microphone ideal for portable applications, but would work nicely in a home studio setting. It can operate on battery power (AA) or phantom power.
There is some wear and tear but the microphone works well. It was used by a former BBC sports reporter for interviewing top athletes.
Specifications:
ELEMENT - Fixed-charge back plate, permanently polarized condenser
POLAR PATTERN - Omnidirectional
FREQUENCY RESPONSE - 20-18,000 Hz
MAXIMUM INPUT LEVEL - Phantom: 137 dB SPL, 1 kHz at 1% T.H.D., Battery: 123 dB SPL
DYNAMIC RANGE - PHANTOM: 113 dB, 1 kHz at Max SPL, BATTERY: 99 dB, 1 kHz at Max SPL
SIGNAL-TO-NOISE RATIO - 70 dB, 1 kHz at 1 Pa
PHANTOM POWER REQUIREMENTS - 9-52V DC, 2 mA typical
BATTERY - 1.5V AA/UM3, 1200 hours typical
OUTPUT CONNECTOR - Integral 3-pin XLRM-type
