PJRandallChevik Posted September 8, 2008 Report Share Posted September 8, 2008 I'm looking for a portable way to record my podcasts on the go. I'm thinking about getting a Mini-Disc recorder for it. I need to be able to run 2-4 mics into it, would this be feasible? Quote Link to comment Share on other sites More sharing options...
greenmachine Posted September 9, 2008 Report Share Posted September 9, 2008 2: yes, since MDs are stereo by nature, you would use left and right channel. Depending on the mics you may need adapters.3-4: not without an external mixer, which would make the rig less portable and the end result less flexible.The Zoom H2 SD flash recorder can record in 2 or 4 channel mode from the internal cardioid mics, but they're built-in one-point mics and don't have that much separation. The external mic input is not that great.Ask yourself: Would a stereo recorder be sufficient, why would you need more than 2 channels? Instead of close miking you could move the stereo recorder farther from the sources. Today's recorders are sensitive enough and noise not a major problem like in the days when we used tape. Quote Link to comment Share on other sites More sharing options...
PJRandallChevik Posted September 9, 2008 Author Report Share Posted September 9, 2008 2: yes, since MDs are stereo by nature, you would use left and right channel. Depending on the mics you may need adapters.3-4: not without an external mixer, which would make the rig less portable and the end result less flexible.The Zoom H2 SD flash recorder can record in 2 or 4 channel mode from the internal cardioid mics, but they're built-in one-point mics and don't have that much separation. The external mic input is not that great.Ask yourself: Would a stereo recorder be sufficient, why would you need more than 2 channels? Instead of close miking you could move the stereo recorder farther from the sources. Today's recorders are sensitive enough and noise not a major problem like in the days when we used tape.Thanks for the advice, I was thinking about using a daisy-chain of splitter/mergers for 3 or more people. What do you think of that? Quote Link to comment Share on other sites More sharing options...
