Problems Recording with a MZ-R900
zmackid
Hi all,
I did some interview recordings with my MZ-R900 in LP2 format. When I recorded from the end of a disc which has already 40 plus minutes of material, it failed to record. There were indications of recording (the input bar fluctuated, red light came on, I could even hear the recording when I insert earphones while recording) however when I playback, there was silence (the output bar does not fluctuate).
So I tried recording on a blank disc thinking it was equipment failure but there were no problems recording. When I used another disc which had 50 over minutes of material the problem returned. Could the issue lie with my MDs instead? They are 74-minute MDs but I understand the LP technology allows me to record longer than that and my MD supports LP playback.
Has anyone faced similar problems? I currently don't have access to another MD player, so I'm not sure if it might be a playback issue and my interviews were actually recorded on those "faulty" MDs.
Thanks in advance.
