squeezebox (duet) to MD
1kyle
Hi all Squeezebox to MD works an absolute treat - I play the OPTICAL OUT on the squeezebox into the Optical IN on whatever MD I'm using and encode in SP, LP2 or HI-MD depending on what I need the MD for (LP2 usually goes in the car or portable listening). I still like the sound of SP the best but probably there's really very little in it between SP and Hi-MD.
The aqueezebox can also give quite high quality Internet radio as well (for example WGBH HD2 Boston classical station at 128 kbs --fine for creating LP2 discs) and there are even a few stations now at 292 kbs --perfect.
Real time is not a problem asd I'm listening anyway to the squeezebox -- which plays Native flac files saving a conversion and using the squeezebox's optical out you don't need to use the built in DAC converter.
Editing tracks can be done with SS and you don't need to transfer anything to the library.
Cheers
-K
nope
Digital S/PDIF outputs:
Optical and coax digital connections Dedicated high-precision crystal oscillators (no PLL, no resampling) Standard IEC-958 (S/PDIF) encoding Optical connector: TOSLINK 660nm Coax connector: RCA, 500mVpp into 75 ohms Sample rates: 44.1Khz, 48Khz Audio format: linear PCM, 16 or 24 bits per sample Intrinsic jitter: less than 50ps (standard deviation)
no encoder .........
Edited by Guitarfxr
