Mister Clean Posted March 30, 2006 Report Share Posted March 30, 2006 Whith SonicStage, or others softs, is it possible to recording/encoding in ATRAC, with increasing volume ??? (for a NW-E507, it's not luxe...)Thank's Mister Clean Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted March 30, 2006 Report Share Posted March 30, 2006 Sorry I`m unable to understand what you mean ??Please Explain more ..or if your have problem in writing english then you can also use some translater .. Quote Link to comment Share on other sites More sharing options...
0 Mister Clean Posted March 30, 2006 Author Report Share Posted March 30, 2006 shit, my english is very poor !!!Well,is it possible to record / encoder by increasing the noise level, by increasing the volume of the music ???Capito ???Mister Clean Quote Link to comment Share on other sites More sharing options...
0 madleet3 Posted March 30, 2006 Report Share Posted March 30, 2006 (edited) its oke mr clean i am also a bad english forumer user too ehheas for your questions i doubt any s/w tat left u edit atrac filesmaybe for mp3s but not for atrac unless someone else knows it? Edited March 30, 2006 by madleet3 Quote Link to comment Share on other sites More sharing options...
0 bogon07 Posted March 31, 2006 Report Share Posted March 31, 2006 Windows sound recorder has the option to increase or decrease the volume of a wave file by 25% increments. It would be possible to use that to increase the volume of a song in *.wav format then import it into SonicStage to convert to an ATRAC file.Dedicated audio editing programs may have more options open to manipulating sound files but probably not directly on ATRAC files. Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted March 31, 2006 Report Share Posted March 31, 2006 YEAH!!,It`s not possible to increase or decrease tthe Volume of Atrac files . Quote Link to comment Share on other sites More sharing options...
0 MZ-1 Posted March 31, 2006 Report Share Posted March 31, 2006 I haven't found a way for ATRAC, either. I don't think there is a nomalization option in Sonic Stage. The only issues with volume I might have are some very early (1983-1985) CD's which were usually mastered with less compression and lower overall levels to avoid any possibility of distortion (back in the days when CD was fighting for marketshare).Generally, I find that the volume of the recordings transferred via ATRAC match those of the internal FM radio so I'm happy.Paul Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted March 31, 2006 Report Share Posted March 31, 2006 I don't think there is a nomalization option in Sonic Stage.Normalization option is available for Atrac CD. Quote Link to comment Share on other sites More sharing options...
0 unixseb Posted March 31, 2006 Report Share Posted March 31, 2006 i suggest you normalize your audio datas before encoding them to atrac format.what i do is rip the cds in wav files, normalize the waves and then convert them to mp3 (or any other format) Quote Link to comment Share on other sites More sharing options...
Mister Clean
Thank's
Mister Clean
8 answers to this question
