MZ-RH1 and 16 bits soundcard with Toslink
sefarad
Hi everybody.
I wonder if you can help me.
I want to record in my RH1 from the 16 bits PC soundcard. It has toslink connect input/output.
If my soundcard was 24 bits with toskink connectors, Could I get better results?. That is, Could the number of bits or the quality of soundcard affect the final results using tosklink connection?.
Thank you in advance!.
Edited by sefarad
  sefarad said:
Hi everybody.
Nope. And I don't know for sure if the RH1 will accept signals higher than 16bit.
