albero23 Posted April 19, 2006 Report Share Posted April 19, 2006 hi to allwhere i could find the original earphones of the nwa1000?maybe could i get theme for free from sony's site? (like Ipod do)in shop how much could them cost?thanks Quote Link to comment Share on other sites More sharing options...
0 pata2001 Posted April 19, 2006 Report Share Posted April 19, 2006 Based on the pics, I would assume that they are E931. Sony sell this seperately, so I doubt that you can get them for free. Quote Link to comment Share on other sites More sharing options...
0 albero23 Posted April 19, 2006 Author Report Share Posted April 19, 2006 i dont think soanyway whats is a good model of earphones with a high quality (like sony nwA1000 or Ipod earphones)not so expensive (max 40 euros)also other brands not only sonythanks Quote Link to comment Share on other sites More sharing options...
0 pata2001 Posted April 19, 2006 Report Share Posted April 19, 2006 I would not consider the iPod stock bud as "high" quality. It is just a generic stock bud, the same level as Sony E808, hyped with the iPod brand. It seems there are 2 distinct features that people consider as "high" quality. Some people will attribute boomy bass as "high" quality, while other will look more for a well-balanced sound as "high" quality.If you like bass, you can get Sony MDR-E10. They're cheap, and has boomy bass, although the overall SQ is not as good/well-balanced as other buds like the E838. Next step is Sony EX51/71, again if you like phones that are tuned for bass and treble. Quote Link to comment Share on other sites More sharing options...
0 mascis_ Posted April 20, 2006 Report Share Posted April 20, 2006 dont know how much is it in euros but it should be in your price range.Standard earphones, Check out Sennheiser MX-500..brilliant mids, typical sennheiser sound, clear and spacious and really cheap. But stay away if youre into heavy bass. To me, i use it only when im working (like right now) coz it comes with a volume control thingyFor in-ear types check out Panasonic RP-HJE50(i use this for travel and leisure) and/or Creative EP-630. the latter is supposedly better but its a Y-cord type. The pana is your typical Sony round-the-neck type(one side longer than the other). Both are said to be better than sony. Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted April 20, 2006 Report Share Posted April 20, 2006 I don`t have the price of CX300 in euro but this is also a good option. Quote Link to comment Share on other sites More sharing options...
0 mascis_ Posted April 20, 2006 Report Share Posted April 20, 2006 I don`t have the price of CX300 in euro but this is also a good option.forgot all bout that...should be less than 40 euros...remember seeing it on ebay uk for around 30eurosits a round the neck type if im not wrong..reviews for it has been good too if i remember correctlythen theres the Panasonic RP-HJE70..top of the line..qualitywise not too sure..i think audiocubes.com has it Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted April 20, 2006 Report Share Posted April 20, 2006 remember seeing it on ebay uk for around 30eurosIs it including shipping ??? Quote Link to comment Share on other sites More sharing options...
0 mascis_ Posted April 20, 2006 Report Share Posted April 20, 2006 Is it including shipping ???not too sure, could be an active auction too...try finding it out in ebay uk Quote Link to comment Share on other sites More sharing options...
0 albero23 Posted April 21, 2006 Author Report Share Posted April 21, 2006 thanks to all!i'll check this advices and then i'll tell you my decision Quote Link to comment Share on other sites More sharing options...
albero23
hi to all
thanks
9 answers to this question
