Which software gives the best sound
dragulagu
This is a little bit off topic for the attrac forum, but I ask it anyway.
I currently have an AC97 realtek card (18 bit) on my laptop and I was wondering, which software is the best for mp3/audio playback, I am using winamp now, but I wonder if there is a better software out there. Or maybe a plugin for winamp itself. I'm someone who pays attention to bass, so it would be nice if that program also supports a good bassvolume equalizer.
Greets,
Greets,
I don't know how keen your ears are, but you really can't get any better than winamp.
Great support and great plug-ins. You have an equalizer so you can tweak your levels.
Your fine with Winamp.
PS - In any event laptops don't have such great speakers ya know?? ...unless you have it hooked up to speakers. :wave:
I know, I rarely use the boxes, i mostly use my headphones on my laptop, but what i also mean is, are there plugins which improve the equalizer and such of winamp?
yeah im sure there are a few plug-ins, do a search for an 'output' or 'dsp/effect' plugin
Edited by JSP62
Guest Stuge
You can use DFX
Guest Stuge
And wow! This really gives a difference in bass and clearity in
sound, thx man, DFX is great
But remember to unlock it`s abilities you will need to purchase it .
