Sony MZ RH1 + Micro Capsules Sennheiser , eBay France
PhilippeC
http://cgi.ebay.fr/Minidisc-Sony-MZ-RH1-Micro-Capsules-Seinhesser-/160668837708?pt=FR_LC_TV_Son_Home_Cinema_Audio_Portable_Radio_Baladeurs&hash=item25689be74c
interesting auction :
- a mint condition , MZ-RH1 + all accessories
- high-end Seinhesser ear phones available to support music at high level (highmy expensive as you can see by yoursef here : http://www.microphonemadness.com/products/mmtrunathook.htm)
MM-BSM-8 True & Natural Hook On In-Ear Binaural Stereo Microphones
Now available, optional "Sennheiser" Driven micro-sized capsules (omni-directional )!!! Incredible sound quality...guaranteed!!! These are matched sets and are high-end microphones.
The (MM-BSM-8) True & Natural Hook On In-Ear Stereo Microphones are a set of miniature in-ear speakers modified and designed to give you the "most" realistic and accurate binaural stereo recordings!
Totally flexible and form fitting the (MM-BSM-8) will give you hours of comfortable recordings hands free! Microphones install quick and easily over the ear and slide into and next to the opening of each ear. When installed correctly microphones will not fall out! Comes standard gold plated 90 degree 1/8" stereo plug for even greater flexibility. Cable lengths are 52".
*In-Ear Binaural Stereo Microphones "do not" block your hearing ability!
These microphones have a very naturally crisp sound, providing deep bass, smooth mid-range and clean high-range with a frequency response of typically +/-2dB. They can be easily plugged into any Minidisc, Dat or analog recorder that supplies a bias voltage of between 1.5 to 10 volts D.C. (also known as plug in power) at the microphone input jack.
Note: If your recorder does not provide a bias voltage or if you want to feed your recorders line inputs to avoid overloading your recorder's mic pre-amplifier, you can use one of our Battery Modules (check out our Battery-Module Section).
Battery Modules will power the microphones with optimum power ( 9 volts D.C ), increase dynamic range and enable the mics to handle higher (SPL) sound pressure levels ( loud sounds ) without distortion.
Specifications
  • Frequency response: 20- 20,000 Hz
  • Signal to noise ratio: 62dB, 1khz at 1pa
  • Open circuit sensitivity : -35dB (5.6 mv) re 1v at 1pa
  • Dynamic range: 95dB, 1kHz
  • Maximum Input Sound Level: 105dB SPL (120 db when used with one of our battery modules), 1kHz at 1%
Features
  • Flat frequency response
  • Requires a bias voltage of 1.5 to 10 volts D.C. (also known as plug-in- power) or one of our battery modules.
  • Includes Life- Time Warranty at no extra charge!
<p id="item_in">
Sennheiser Specifications
  • Signal to noise ratio: 65dB, 1khz at 1pa
  • Open circuit sensitivity : 10 mV +/- 2.5 db re 1v at 1pa
  • Maximum Input Sound Level: 130dB max SPL with out a battery module!
<p id="item_in">
Sennheiser Features
  • Requires a bias voltage of .9 to 15 volts D.C. (also known as plug-in- power) or one of our battery modules.
Accessories
