gjuro76 Posted June 26, 2006 Report Share Posted June 26, 2006 1) Is there any way to play wma files on NW-HD5, or should I say firmware that allows me to play WMA directly (without conwerting in SS).2) When I add new playlist on my NW-HD5 it's not put alphabeticly. How to correct that?3) Any hacked or regular firmware with which I can see both times: from beginig of the track and 'till the end of the track at the same time?I use Nw-hd5 with SS 4.0CPThanx for answeringGreetings from Zagreb, Croatia, Europe!!! Quote Link to comment Share on other sites More sharing options...
0 bojsa Posted June 27, 2006 Report Share Posted June 27, 2006 1.) No, try converting the wma to mp3 or ATRAC...2.)Ne znam 3.)Noup...Nisam ti mnogo pomogao,ali sta da radim i ja sam se to pitao,ali nisam nasao odgovor...Jedno pitanje za tebe:Da li ima da se nadje baterija za njega u Zagrebu?Pozdrav iz Beograda Quote Link to comment Share on other sites More sharing options...
0 gjuro76 Posted June 27, 2006 Author Report Share Posted June 27, 2006 Na zalost od baterije nista! Mislim da cu je morat preko e-baya nabavljati!Kad mi ova prdne. Zasad radi OK. I to vec godinu dana! Quote Link to comment Share on other sites More sharing options...
0 bockers Posted June 27, 2006 Report Share Posted June 27, 2006 gjuro76 said: 1) Is there any way to play wma files on NW-HD5, or should I say firmware that allows me to play WMA directly (without conwerting in SS).2) When I add new playlist on my NW-HD5 it's not put alphabeticly. How to correct that?3) Any hacked or regular firmware with which I can see both times: from beginig of the track and 'till the end of the track at the same time?I use Nw-hd5 with SS 4.0CPThanx for answeringGreetings from Zagreb, Croatia, Europe!!!Tracktimes can be seen if you have the RMC 35 remote control Quote Link to comment Share on other sites More sharing options...
0 bojsa Posted June 28, 2006 Report Share Posted June 28, 2006 gjuro76 said: Na zalost od baterije nista! Mislim da cu je morat preko e-baya nabavljati!Kad mi ova prdne. Zasad radi OK. I to vec godinu dana!To znaci da ja ne trebam brinut, moj sony je star tek 6 meseci... Quote Link to comment Share on other sites More sharing options...
gjuro76
Thanx for answering
4 answers to this question
