anders260 Posted June 30, 2006 Report Share Posted June 30, 2006 Hi allHave finally found a protective silicon case for my NW-A608 http://www.brightonnet.co.jp/english/produ...o/bmp-sosi.htmlI will give feed back on the quality when i recieve itRegards Anders Quote Link to comment Share on other sites More sharing options...
0 anders260 Posted June 30, 2006 Author Report Share Posted June 30, 2006 Another nice leather case.http://arcconcept.com/leather_n/strap_ash/s_incese.htm Quote Link to comment Share on other sites More sharing options...
0 madleet3 Posted July 2, 2006 Report Share Posted July 2, 2006 wow the leather one looks exclusive Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted July 2, 2006 Report Share Posted July 2, 2006 Hi allHave finally found a protective silicon case for my NW-A608 http://www.brightonnet.co.jp/english/produ...o/bmp-sosi.htmlI will give feed back on the quality when i recieve itRegards AndersNice Find Quote Link to comment Share on other sites More sharing options...
0 anders260 Posted July 3, 2006 Author Report Share Posted July 3, 2006 Found another Silicon casehttp://www.proporta.com/F02/PPF02P05.php?t...&t_mode=des Quote Link to comment Share on other sites More sharing options...
0 drkhades Posted July 5, 2006 Report Share Posted July 5, 2006 Hmm... I have those silicon case before. I think they are alright but I wish there was some protection for the empty part. (The empty part exposes the screen =/). Quote Link to comment Share on other sites More sharing options...
0 anders260 Posted July 5, 2006 Author Report Share Posted July 5, 2006 Hi drkhades,were you satisfied with the case ( apart from the empty part of the screen)? did you buy the one i have ordered (http://www.brightonnet.co.jp/english/produ...o/bmp-sosi.html)? can you press the the play button when it's in the case?Anders Quote Link to comment Share on other sites More sharing options...
0 beeus Posted July 5, 2006 Report Share Posted July 5, 2006 Anders,I purchased a couple of what looks like the same silicon skins from a vendor on Ebay. Thus far I've been quite happy with them. I used one on an E507 and the other on an A608. The areas that cover the buttons are slightly raised and make it quite easy to use the buttons on the player.I've heard complaints about how the display is unprotected but that hasn't bothered me much. That could be fixed quite easily with just a little bit of clear vinyl placed between the skin and the player.The manufacturer of the skins I purchased also sell them online but I believe the shipping is a bit high as they are coming from Asia. The link is below for those interested. I tried to directly link to the NW-E507 skin but it doesn't seem to get there. Click on products then scroll down to the end of the list to see the skins made for Sony devices.http://www.lajo.biz/Xskn/index.aspI hope this info helps! Quote Link to comment Share on other sites More sharing options...
0 anders260 Posted July 5, 2006 Author Report Share Posted July 5, 2006 Hi BeeusThanks for the reply, "The areas that cover the buttons are slightly raised and make it quite easy to use the buttons on the player" so you can press the buttons on the player even when the case is on ( even the play /stop button?Anders Quote Link to comment Share on other sites More sharing options...
0 drkhades Posted July 5, 2006 Report Share Posted July 5, 2006 I got the same case on ebay about a couple months ago. The buttons are slightly raised making it easy for you to navigate if you have big fingers. I'm very satisfied with the case even with the unprotected display. Other than that, just beware of dust being attracted to the silicon case. Quote Link to comment Share on other sites More sharing options...
0 beeus Posted July 5, 2006 Report Share Posted July 5, 2006 "So you can press the buttons on the player even when the case is on ( even the play /stop button?"Yup, the player works as if the skin isn't even there. Quote Link to comment Share on other sites More sharing options...
anders260
Hi all
Regards Anders
10 answers to this question
