TEK Posted July 2, 2006 Report Share Posted July 2, 2006 Hi All !!!I have a question about my a3000. When you go to Music Library/Playlists I see those B.mark List 1, 2, 3, 4, 5,Is there any way to remove them ???Thanks a lot. Quote Link to comment Share on other sites More sharing options...
0 Pulse Posted July 3, 2006 Report Share Posted July 3, 2006 I don't think so. Those menus are built directly into the device database files. Those bookmarks aren't actually playlists they are designed more like menus to bookmarks, so I'm doubtful that you can delete them. (ie you can only delete their contents). Quote Link to comment Share on other sites More sharing options...
0 TEK Posted July 3, 2006 Author Report Share Posted July 3, 2006 Oh, I see, Thank you Quote Link to comment Share on other sites More sharing options...
0 Bewarethefoxxx Posted July 4, 2006 Report Share Posted July 4, 2006 Besides, you wouldn't want to delete them surely? They are really useful for creating a playlist on your device without having to connect the device to the connect player software. I often use the bookmarks on the move, if there are certain songs I want to listen to I quickly add them to a bookmark list and play them in the order I specified. Quote Link to comment Share on other sites More sharing options...
TEK
Hi All !!!
Thanks a lot.
3 answers to this question
