NW-E405 Device Issue
AntiPod
hey guys!
i was trying to install the firmware update v2.0 for my nw-e405 yesterday, everything went all right til i was trying to install it into my walkman.
i had connected my walkman to my pc, and it was recharging itself. Then the installation stopped because it says" the device wasnt connected". But i still could open it from "my computer" as the E: drive.
same problems occured when i connect the walkman and sonicstage also says the device isnt connected
please help me solve this problem!
oh and for the ones who had installed the update, i have a few questions to ask:
it says b4 the installation: "it is not guaranteed that the files in your device will not be damaged or blahblah..."
hawe any of you had your music lost or damaged because of the update? and for the change of the calendar, is the date still on it? i only saw time on the sony website..
4 answers to this question
try flashing your player for one last time...if it doesn't work go to the nearest sony official, coz it's really dangerous when half flashing is done and the player isn't recognized. Use the search function, people have got similar errors
You should make sure that your E405 is fully charged before starting a firmware update.
Didn't have any problem with existing music files on the device after update.
I didn't think there was a calendar on the E400/500 only the A1000/1200/3000 after the last update.
thanks u so much~
i havent done the update yet, thx for the information, but i would like to hear more opinions from u all plz
Edited by AntiPod
