MZ NH900 Usb Cable
AVITWeb
Good morning all.
Just wondering if anyone knows where I can get a new USB cable for my 900. The rubber is disintigrating around the connectors (not really sure why.) It is getting tacky and then eventually it just falls off. I know there is a difference between the cables because I once tried to use my standard MD cable for my 900 and had all kinds of problems. Any help would be terrific.
Thanks!
Actually, from what a previous post has said, the "NH900 uses a standard A to Mini B USB cable" so the cable from your standard MD device should have worked fine, unless either that cable is faulty or the device is.
That being said, A to Mini B cables are cheap as chips and can easily be found on Amazon, eBay, and many shops.
