punkrockaddict Posted November 2, 2013 Report Share Posted November 2, 2013 I trying to figure out if it would be possible to fix a broken RH1 with parts from a working RH10. As the Rh1 has a defect Laser and is missing its overwrite head it´s kinda useless atm. I took a look and compared both and came to the idea of replacing the top of the insert mechanism. I didn´t go any further till now. But i´ll try this tomorrow. Unfortunately Jim don´t read my messages so i have to find this out by myself ;-) The RH10 is all good and has had very low recording horus srored in its memory but the casing is cracked and the display is dead. So this would be a perfect match to get one player working again That would be RH1 #6 if i succeed. I guess nobody holds spare parts for the RH1 here, right? Quote Link to comment Share on other sites More sharing options...
punkrockaddict Posted November 3, 2013 Author Report Share Posted November 3, 2013 hell yeah this was one of a masterpiece as it worked like hell. I´ll upload pics soon. One thing i can say is that the RH1 plays again I only need to put the case back together and then i´ll try to upload some discs. The soldering is not what one should try at first instance but i managed it.Did it one time before with a NH900 so wasn´t that hard at all Any comments on this ? Quote Link to comment Share on other sites More sharing options...
PsychoPimpKiller Posted November 14, 2013 Report Share Posted November 14, 2013 Where are the pics at? I am curious to see it. Quote Link to comment Share on other sites More sharing options...
punkrockaddict Posted November 14, 2013 Author Report Share Posted November 14, 2013 Yea i forgot about.I´ll post them after lunch now I had the unit already playing when it was just fixed.But lately i , to my bad luck, bend the Overwritehead by myself as was was puzzling the thing together. So its a player right now Quote Link to comment Share on other sites More sharing options...
