Problems with HDD on NW-HD3.
first
When i try to transfer 4,35 GB image files to the HDD on my NW-HD3 i am getting this message:
"The disk in the destination drive is full.
Insert a new disk to continue."
I have done it ones before, then with no trouble.
The Hard Disk is emty, have initialize the Hard Drive. (From the menue on the NW-HD3)
Small files have no problem to be transferred. (it is some space, mybe arond 4 GB that i can use. Total space is 18,6, it showes now 14,3GB free.
I have used GYM. Could that be a problem? Only prepeared for 100 songs.
Is it possible to format in a better way?
I need help!
8 answers to this question
Guest Stuge
How do i do that? In SS 4.0 under the "Controls" - "Device/Media"-menu, "Initialize" is grey and can't be used.
First press "Menu " button ,then scroll down to "Format .Select Format & Initialize the hard disk .
I have also tryed with many small files (<1,5GB) but I got the same message when the files total transferred was >3+GB.
