I am running Windows XP with SS3.4 US version. I have a refurb HD3
I've been using this device for months with no issues. Last night, while I was transferring music to the unit through SS, my PC had a hard crash (blue screen). I rebooted the machine and brought up sonic stage. I deleted the albums that I was transferring during that session since I didn't know just where it crashed. As it went though this process, it generated an error that it couldn't reconcile a bunch of file names called "unknown". Hit OK and it would start the process all over again.
Thinking that this had to do with the newly imported file in SS, I removed those from SS. Still same problem. I then took the drastic measure of initializing my HD3. Even with all of the music removed from there, I had the same problem.
Then I took the really drastic measure of uninstalling SS and reinstalling it. After uninstalling, I removed the entire Sony and Sony coporation directories and registry key hives. I still have the same problem!!
The message box that comes up when I connect the unit to SS is "Checking if any tracks were deleted without being transferred back to My Library. The deleted rights information of these tracks will be recovered (The remaining transfer count will increase).
After an attempt to do this by clicking OK, the message box comes up again. If I press OK, I then see a message box that says "An error occured while transferring. The rights information (MAC) of the track is invalid. Below that are a bunch of line that say "Untitled".
I've even tried deleted the contents of OMGAUDIO on the unit through Windows Explorer.
I am stuck and am now at a loss of what to try next.
maggior
Thanks for any suggestions.
Rich
1 answer to this question
