Ralf den Hartigh Posted November 24, 2014 Report Share Posted November 24, 2014 I try to transfer a mp4 file that i have prepared in Video to Video to my nw-a806 device using windows explorer instead of Image Converter. In the QuickStart Guide (page 20) of the device there is mentioned how this can be done. All my attempts result in a 'Format not supported' on the device. Has anyone succeeded in transferring in a successfull way? Ralf Quote Link to comment Share on other sites More sharing options...
0 Ralf den Hartigh Posted November 25, 2014 Author Report Share Posted November 25, 2014 Tnank you Jan! Your message has solved my problem. I downloaded Format Factory and used it as you directed. Rusult: succes! greetings, Ralf Quote Link to comment Share on other sites More sharing options...
0 kalkie Posted November 24, 2014 Report Share Posted November 24, 2014 I tried this on my NW-A805 (is the same as NW-A806) and indeed you can transfer the file with windows explorer. But the file must have the right format (MPEG-4 QVGA(320x240)) and you must create a map on your device named "VIDEO" to contain the videofiles. I always use FormatFactory (is free software) to convert the video to the right format if needed. To test it on my NW-A805 I downloaded a musicvideo from YouTube and converted the downloaded file with FormatFactory to "MP4 320x240 MPEG4" and copied the file with windows explorer to my NW-A805 in the map VIDEO and the video played succesfull. Jan Quote Link to comment Share on other sites More sharing options...
Ralf den Hartigh
Ralf
2 answers to this question
