sharkzor Posted April 11, 2015 Report Share Posted April 11, 2015 So, what do you guys use nowadays to record MD's? When i connect a (sony) cd player to md my deck, it will sync rec and do autogap and stuff. It's difficult to get some modern (not meant for windows 98) software to do this the same way. i have NET-MD, but once i found out sonic stage is lowering the bitrate even with SP, i stopped using it. I only record through optical. What do you recommend? I manly use a mac (optical out), but a pc is also available. Quote Link to comment Share on other sites More sharing options...
PhilippeC Posted April 12, 2015 Report Share Posted April 12, 2015 For Windows (find similar settings for your Mac) : a very good internal or external audio sound card, real time digital recording, Wasapi/ Asio DSP audio output, plugins like Wincue or Post-track Silence to create gaps (except live recordng), Windows settings no sound and control by the application (player), eventually the Replaygain plugin, players like Winamp or foobar 2000... and a good MD recorder (type R or type S generations, Hi-MD). Quote Link to comment Share on other sites More sharing options...
