rocketor Posted August 13, 2006 Report Share Posted August 13, 2006 Hi to all!Just got my nwa1000 walkman (looks realy great) and have few questions.1)How long i have to charge the battery for the first time? And should i charge it from usb (i heard its better for the battery??) or the adapter??2) should i install the connect and uptade it or go for sonicstage 4 ?????Thank you!!! Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted August 13, 2006 Report Share Posted August 13, 2006 Use AC adapter ,charging will be much faster .First Try Connect & if you able to bear it ,then go with it .If not ,Then Use SonicStage CP 4 . Quote Link to comment Share on other sites More sharing options...
0 aznbro85 Posted August 13, 2006 Report Share Posted August 13, 2006 Hey rocketor, Welcome to ATRACLife Colloquium, and hope you enjoy your stay Like what Stuge said, you should charge via the AC adapter. As to answer your question about how long to charge it, when you charge it, the data cable has a red light that lights up. When the charging is done, the light will be off, and you'll know that it's done charging.Personally, I'd go with installing SonicStage CP, since Connect player is more or less DOA. I think they might have a few more updates for Connect, but it looks like the horse that they tried to kill (SonicStage) will be here for the long haul.. haha Quote Link to comment Share on other sites More sharing options...
rocketor
Hi to all!
Thank you!!!
2 answers to this question
