I did a deep seach before posting this but couldnt find a solution for my prob.
Here is the prob:
I cant format my player with the build-in format menu. It dont even begin formating, just quits format menu.
I cant initialize - rename - delete current song (there is only 1 song in device 11min. with an ® symbol in id tag and name) from sonicstage v3.2 bundled with device and 4.0 from web. When I delete or rename everything seems fine but in 1-2 minutes the old mp3 appears again. I delete, it comes back, I delete again, and it cames back. I also delete from windows explorer but the file suddeny appears in 1 minutes like a horror film
As I read from forums if you format USB from explorer I cant use it with device ad mp3 player till I reformat by buildin format. So I must be able to format from explorer. But I cant it cant complete format %99 and it gives error
Can the USB flash be damages somehow, bad sector??? I didnt do anything bad, drop wet etc.. and device is new !!!! Just transfered twice.
I contacted with eurasia sony support in my country and still they couldnt fix by telephone since I bouglt is from japan I dont have a warranty paper. Im in europe now
I cant transfer anything new to device, it says "the device is not ready" or "unplugged" and old files came back again
Im really dissappointed with this product, please help.........
smarty
Here is the prob:
3 answers to this question
