New Sony Headphones & Earphones Announced!
Ishiyoshi
It has come to our attention that Sony will be adding a new fleet of headphones and earphones this October and November respectively. The new 'phones:
*image courtesy of AVWatch; check back for detailed specifications
MDR-NC22
~ successor to the MDR-NC11, the NC22 will retail for 9,975 yen on October 10, 2006. The MDR-NC22 will be available in three color scheme: Black, White and Pink.
Specifications
Type: Closed, Dynamic
Driver Unit: 13.5mm diameter (CCAW voice coil adoption)
Power Handling Capacity: (IEC)
Impedance: Ω(1kHz)
Sensitivity: dB/mW
Frequency Response: Hz
Cord: OFC, approx. 1.5m
Weight: approx. 39g (inclusive of battery)
Plug: L shaped stereo mini plug (Gold)
Battery Life: approx. 50hrs
Color: Black, White and Pink
MDR-EX85SL
~ with an expected price of 5,000 yen. The EX85SL employs the same driver as the 90SL - most likely a budget version of the latter.
MDR-EX52SL
~ due this November with an expected MSRP of 3,000 yen.
MDR-EX32SL/LP
~ standard canal 'phones; due this November with and expected MSRP of 2,500 yen. Will be available in four color scheme.
MDR-D777SL
~ The MDR-D777SL will feature 40mm HD driver units with a frequency range up to 80kHz and a "sound isolation mode" switch. The headphone will be available for sale on October 10, 2006 with a MSRP of 24,675 yen.
Specifications
Type: Sealing Closed, Dynamic
Driver Unit: 40mm diameter (CCAW voice coil adoption)
Power Handling Capacity: 1,500mW (IEC)
Impedance: 24Ω(1kHz)
Sensitivity: 106dB/mW
Frequency Response: 8-80,000Hz
Cord: OFC, 0.5m with 1 m extension cord
Weight: approx. 166g
MDR-D333LW
~ The MDR-D333LW will be available in three color scheme (Silver, White and Red) on October 10, 2006 with a MSRP of 6,195 yen. The MDR-D333LW will feature a convenient recoiling cord mechanism. 'phones cord can be wound up by pressing a button on the side of its housing.
Specifications
Type:Sealing Closed, Dynamic
Driver Unit: 30mm diameter (CCAW voice coil adoption)
Power Handling Capacity: 1,000mW (IEC)
Sensitivity: 102dB/mW
Frequency Response: 12-24,000Hz
Cord: OFC, approx. 1.5m winding cord
Weight: approx. 136g
Color: Silver, White and Red
Wow! Return of the EGGOs! :D I have a bad feeling that none of these would come to the US though. :( Maybe the earbuds, but no SL cords. Oh, and the EX85SL doesn't look like a canal phone. The D333 looks interesting. Of course, time for Sony USA to shaft US customers once again if none/only a few of these come to the US.
Hmmm, from the model numbers, the EX85s are going to have the usual canalphone action going. Just not quite evident from the pictures. Otherwise, it'd probably be a part of the MDR-E8X8 line...
I must say I want one of those D333s here... They look quite hot, especially in White.
I don't think the D777's will have active noise cancellation in the same sense as the NC11/22's but more what looks like some kind of isolation "on/off" switch. That said they do lack some of the character of the D66's.
could be a simple mechanical switch to slide a membrane* open/c;osed
*like the earlier eggos or could just be a plastic slide
Adrian and Rich are quite right regarding the "sound-in" switch. The description regarding the D777SL's "sound-in" switch is somewhat vague (from AVWatch via Sony Dealer Convention 2006) at this point but it is obvious that this "switch" is definitely not a traditional NC so to speak. I don't see how the D777SL can power NC circuitry without an external power source. (i.e. batteries)
Update: edited initial noise cancellation remark to stem further confusion.
  • 3 weeks later...
