bluecrab Posted March 19, 2020 Report Share Posted March 19, 2020 Question about ATRAC chips: If a chip is, for example, Type R, can it also deploy prior ATRAC versions, or is it that version only? (I'm hoping that "there are no stupid questions" is true!) Quote Link to comment Share on other sites More sharing options...
trott3r Posted March 19, 2020 Report Share Posted March 19, 2020 If you mean write in ATRAC v4.5 then no. type r can play v4.5 though. Quote Link to comment Share on other sites More sharing options...
kgallen Posted March 19, 2020 Report Share Posted March 19, 2020 And all players can play SP discs written with a Type R machine. Quote Link to comment Share on other sites More sharing options...
bluecrab Posted March 20, 2020 Author Report Share Posted March 20, 2020 On 3/19/2020 at 8:33 PM, trott3r said: If you mean write in ATRAC v4.5 then no. type r can play v4.5 though. Expand Thanks for the responses. I meant Write and should have said so explicitly. Any MD can play any ATRAC is pretty well-known. I saw the following on minidisc.org, regarding the MXD-D40 (CXD2662R): "ATRAC Type-R is used only during realtime SP mode dubbing, not for MDLP or high-speed SP mode dubbing." This is not a new subject—I'm just looking at it from a different perspective. Got to wondering how a Type R deck could somehow produce less than Type R in SP mode. I thought that if that were the case, then there would have to be either something in the Type R chip enabling it to do less than R, or else there would have to be a separate chip. Similarly, the Type S (inclusive of R) MXD-D400 (CXD2664R) is thought by some to be unable to effect Type R at 4x...but that seems not true, as noted previously here by sfbp and maybe others. Anyway, it's just not clear to me how such a process could happen. MDLP is by definition a different beast altogether. Quote Link to comment Share on other sites More sharing options...
